I have a 1999 I30. I don't know what happened, but my horn has always worked fine until about 2 weeks ago. I noticed it wasn't working so I checked the 10 amp horn fuse under the hood and it was blown. I replaced it and tried the horn, it gave a very brief chirp but that was it and the fuse had blown again. I replaced the horn relay on the driver side under the hood but that didn't fix the problem. Next, I disconnected the wires from the horn, replaced the 10 amp fuse and hit the horn, it didn't blow the fuse. It only blows when the horns are connected.
Does anyone know what the problem could be? Could it be the horn itself, or maybe a ground? It's always worked great until now. Also I checked every single fuse in every fuse pannel on the car and they were all fine except the 10 amp horn. I've searched the forums for hours and can't find a similar problem. Any help would be great.
