Hooking up a radar detector
sroyj
Car: 2011 Infiniti M37x
A little thing, but I was pretty happy with it and thought I'd share. After getting the M37, I was quick to just plug in the radar detector with the wire hanging down across the dash. I really didn't like that. I tried some searching around for options but didn't find anything I liked. Yesterday I had some time to dig into what's located at the rearview mirror. I found accessory power there and in a matter of minutes was able to tap into that and mounted the detector right under the mirror. This is a great spot for the detector and hookup couldn't have been easier.
Ilya
Nice! I have to get a detector one of these days (I'm thinking the V1, although I hear it has some stiff competition these days).
That being said, you mind providing some information in this thread such as:
1) What wire did you tap?
2) Any other installation information
I'll add this to the FAQ if you can add the necessary info for someone searching Google to do this.
wideopn11
Car: 2012 Infiniti M37x Moonlight White
Takeda CAI
Stillen exhaust w/ MeganRacing Y-pipe
SCALE coilovers 16K/10K F/R
Akebono BBK
Cusco strutbar
25mm spacers F/R
Uprev tune by seymore4
Nicely done, VA sucks. I need super stealth installation.
Ilya
VA? Or did you mean V1? I thought it was hands down the best detector money could buy for like 15 years straight?
BTW, speaking of VA, it does suck. They banned detectors, if you get caught with one they take it. Hate driving through that state.
sroyj
There are 2 plastic covers. The first one is closest to the headliner. It simply pulls straight down. The second one is behind the mirror and pulls straight away from the windshield. With those off you'll see a plug going to the mirror with 3 wires. Black is ground, red is accessory 12V and green is constant 12V. With an Escort it was red to red and black to the green on the Escort cable. That's it. I tapped into the wires, popped the covers back on. Done.
DoN_BLaZe34
Car: 2007 M45 Sport - Sold
2006 FX45 - Traded
2014 Q70S 5.6 - Sold
2017 Q70L 5.6 - Current
IlyaKol wrote:VA? Or did you mean V1? I thought it was hands down the best detector money could buy for like 15 years straight?
Think he meant VA
OP welcome to the forum and job well done! :dblthumb:
Ilya
sroyj wrote:There are 2 plastic covers. The first one is closest to the headliner. It simply pulls straight down. The second one is behind the mirror and pulls straight away from the windshield. With those off you'll see a plug going to the mirror with 3 wires. Black is ground, red is accessory 12V and green is constant 12V. With an Escort it was red to red and black to the green on the Escort cable. That's it. I tapped into the wires, popped the covers back on. Done.
I wonder if it'll be the same for cars with LDW, etc.
sroyj
Think he meant VA
Thanks Don.
sroyj
Good question. I don't know though. Maybe someone else will chime in with an answer.
DoN_BLaZe34
2006 FX45 - Traded
I highly doubt it's any different, but don't know for sure.
Mjkkb2
Car: 2018 Infiniti QX60 AWD
2011 Infiniti M37S
2011 Nissan Quest
2001 Infiniti I30t(sold)
you sure you don't have the black and green backwards ( in your description)? Seems like a more common set up.
sroyj
Yes, I'm sure. That said, I would still encourage anyone doing this to confirm it for themselves.
Mjkkb2
2011 Infiniti M37S
2011 Nissan Quest
Ok, thanks for confirming. I may look into hooking up my dvr there.
sroyj
Mjkkb2 wrote:Ok, thanks for confirming. I may look into hooking up my dvr there.
Good luck. Keep an eye on the current. There may not be a lot to spare there.
wideopn11
Takeda CAI
Akebono BBK
Cusco strutbar
25mm spacers F/R
Yeah I meant VA=Virginia sucks. I used to have a stealth install on my RX7, front and rear sensors hidden in the taillight covers and and under the front bumper. The read out in the cabin was behind the ashtray door. Saved me several times.
SmoovC
Car: '06 Infiniti M45 Premium, Brakemotive, H-Techs, KYB's, USA-Spec PA15-INFI w/ BT streaming, Kuda cell mount, Magnaflow exhaust. (CAR SOLD)
Current: 2012 Infiniti M56S, Harbour Blue, 4 pc Aero Kit
There is also an easily accessible "IGN only" wire under the driver's dash at the firewall. It is a 12 gauge wire, and is blue in color.
securityguy
You cannot take RED to RED and BLACK to GREEN as described above. RED to RED and BLACK to BLACK is the only way this will work. You stated RED was ACC Power and GREEN was constant 12VDC. Two POSITIVE connections will not work. I honestly think he meant to say what I just stated and got his colors mixed up.
sroyj
securityguy wrote:You cannot take RED to RED and BLACK to GREEN as described above. RED to RED and BLACK to BLACK is the only way this will work. You stated RED was ACC Power and GREEN was constant 12VDC. Two POSITIVE connections will not work. I honestly think he meant to say what I just stated and got his colors mixed up.
What I was trying to say, maybe it wasn't clear, was the red on the car to the red on the escort cable, and black on the car to the green on the escort cable. Does that clarify?
RadarRoy
The V1 has long lost it's glory of being the best detector, today Escort's line is much superior with GPS, stealth, internal bluetooth.
BTW, VA banned detectors a long time ago, and they use a device called the Spectre to detect them and it's why you need a stealth detector like the Redline to defeat them.
If you have any questions about detectors or jammers let me know, be glad to help
I have a video here on how the Spectre works: http://youtu.be/NCzc4-RShaU
Think he meant VA
Ilya
RadarRoy wrote:The V1 has long lost it's glory of being the best detector, today Escort's line is much superior with GPS, stealth, internal bluetooth.
Thanks Roy. I've been reading more and more about the Escorts (I think the newest best one is called the Max?) and have been conflicted.
sroyj
I've had the Max for about 6 months now. I love it. My PASSPORT 8500 X50 served me very well for about 12 years, so I didn't hesitate to get another Escort. I don't know the Valentines, so I can't compare them. I do love the GPS functionality of the Max; sensitivity automatically does up and down with your speed. It will automatically learn where all the false signals are and learn to ignore them. Pretty cool.
Ilya
Yeah it does seem quite nice. The new Max 2 is likely the one I'll get.
NoTalentLoser
There are plans on the internet detailing build instructions and parts needed, but has anyone here ever been brave/bold/stupid (?) enough to use an active radar jammer (e.g., the old Scorpion)? The "renegade" half of my brain wants to buy the circuitry components and follow one of the plans available online to build one... ya know, just to see if it works. :ohno:
RadarRoy
Escort stopped production of the Max 2 months ago and replaced it with the http://www.radarbusters.com/Passport-Ma ... t-max2.htm
The main difference is that the Max2 has an internal bluetooth chip set that enables you to get real time alerts from other Escort detectors in your area. Real neat feature.
RadarRoy
The biggest problem with the old Scorpion is that it jammed only X and K band, not Ka band
Then there was also the problem of having to send it back every couple months to be re-calibrated.
They ended up getting shut down by the FCC think it was around 1996
NoTalentLoser wrote:There are plans on the internet detailing build instructions and parts needed, but has anyone here ever been brave/bold/stupid (?) enough to use an active radar jammer (e.g., the old Scorpion)? The "renegade" half of my brain wants to buy the circuitry components and follow one of the plans available online to build one... ya know, just to see if it works. :ohno:
Ilya
You meant to say they stopped production on the Max for the Max 2, not stopped production on the Max 2 for the Max 2...right? :rotflmao
Larz
Car: 2019 Q70-L RWD
I think we read that wrong, Ilya. He meant: They stopped production of the Max .... 2 months ago .... to replace it with the new Max 2 model.
Ilya
Even funnier :rotflmao. Thanks.
NoTalentLoser
That's interesting to hear, RadarRoy. From what I've read, the online "blueprints" for the newer jammer (I.e., the one you have to build yourself in a DIY fashion) indicate that the device should jam not only X and K band radar, but Ka band radar as well. The only issue seems to be that the transmitters, which have to be purchased separately and are required for the jammer to work, apparently cost $300 - $400 each.
RadarRoy wrote:The biggest problem with the old Scorpion is that it jammed only X and K band, not Ka band
spoons22
Car: 2011 M37x
Technology Package
Has anyone direct wired their radar detector to their fuse box using an add-a-circuit? Thinking this is the route I'm going to go and was just wondering what others people experience was like doing it. Looking at the fuse box Im either tapping into the cigar lighter or audio/mirror fuse.
