Why not park the car in the garage and close the door?Tim30250 wrote:Is there some type of safety feature whereby the homelink button WON'T open my garage door if someone, say, breaks into the car and pushes it?
I tested it, and the button still operated the garage door even with the engine off and the smart key 50 feet from the car. Will the homelink buttons be disabled when the car is locked?
This situation is the same as leaving the car in the driveway with a portable opener inside.Tim30250 wrote:Is there some type of safety feature whereby the homelink button WON'T open my garage door if someone, say, breaks into the car and pushes it?
Telcoman
We live in a safe area, too. There hasn't been a burglary since we moved here 20 years ago. Nevertheless, we keep our doors locked, park our cars in the garage and don't leave stuff outside.i live in a safe area... we don't even lock the house doors
Exactly what I do. Locking the button from the inside pretty much solves the problem.CrackaLackin wrote:If the G never goes in the garage, maybe just don't program it's HomeLink? Personally I would just use the "Lock" feature on the garage door opener at night (if it has something like that)
And yes, this is a limitation of the HomeLink
Few reasons.. The keypad for the home's alarm system is just inside the garage (I was too cheap to pay the extra cash for another by the front door) so it's easier to come in through the garage and turn off the alarm. Secondly, our kitchen is closer to the garage than the front door so it's easier and faster to bring groceries in through the garage. I also like not having to keep a separate remote in the car to operate the door, it's neater and cleaner with the Homelink.zozoka1212 wrote:
To the op. If you have the 2 cars in the garage and the G won't fit in than why do you need the homelink conected.
By that standard, there isn't a safe neighborhood in any city in the United States. If you leave your stuff outside, sooner or later, some lowlife will cruise by and steal it. The "better" parts of town (i.e. more expensive houses) and surrounding rural areas used to be safe. They aren't any longer.zozoka1212 wrote:That doesn't qualify safe area in my book if cars were stolen from your neighburs.
Not exactly. I can have neat and safe. I will continue to use the homelink, but once I get home and enter through the garage I will flick the switch on the inside garage door button to the "lock" position so it won't respond to any signals. Then, the next morning I will flip the switch to "unlock" so I can close the door with my homelink on the way out.zozoka1212 wrote:Well the option is yours. You either pick the safer or the neater way.
So conclusion is if you want to do it safely reset the homelink and use remote and carry it instead of leave it in your car or you can have the neater way and have less safety.
