MATERIALS:
-16 screws no longer than 1 inch. I only bought 8 =\.
-Garage door bottom seal. There's 2 kinds, foam and hard rubber. I got foam because it was the only kind they had and some guy on the other forum said he preferred it. Need about 9 feet.
-3m double sided heavy duty tape. I only bought 5 feet which is why in some of the pictures it looks white because I had to go to a store near by and they didnt have the same kind. I recommend at least 7 feet.
You'll also need a drill and a drill bit smaller than your screw which is the way I did it. Works best that way. Or you can punch holes and use zip ties.
STEP 1: Clean the bumper. I used windex or something I dont remember. Alcohol works well. Make sure the whole bottom side is nice and clean.
STEP 2: Place the tape on the rubber.
Be careful when you're measuring the rubber and make sure you use more than you think you'll need. I roughly measured it by putting it on the bumper and only had half an inch left after it was on lol.
STEP 3: CAREFULLY put it on the bumper. This stuff does not like coming off so make sure you do it perfectly. I rushed so it looks a little wonky but oh well.
STEP 4: Drill holes into it and screw some screws in. Do as many as you'd like but when you screw them in make sure to not screw them so tight as to tear the rubber.
STEP 5: Cut off access with a pair of scissors or a box cutter.
Total materials : 18 dollars
Total time : 15 -25 mins
BEFORE:
AFTER:
Enjoy new lip!
