RobPaulson wrote:i know i could google this . . . but you guys are sooooo good at putting this stuff in lamens terms . . .
whats does the HLSD ACTUALLY do??
The Ultimate Differential
The Helical LSD enables a car to accelerate more rapidly and corner faster. How?Simply by getting the power to the ground.
With an normal open differential, fitted as standard on most cars, much precious power is wasted through wheel spin under acceleration. This happens because the open differential shifts power to the wheel with less grip - along the path of least resistance.
The Helical differential, however, does just the opposite. It senses which wheel has the better grip, and automatically biases the power to that wheel. It does this smoothly and constantly, and without ever completely removing power from the other wheel.
In cornering, while accelerating out of a turn, the unit biases greater power to the outside wheel, reducing inside-wheel spin. This allows the driver to begin accelerating earlier, exiting the corner at a higher speed.
The Helical differential also controls loss of traction when the drive wheels are on slippery surfaces such as ice and snow or mud, providing the appropriate biased traction needed to overcome these adverse conditions. Power is transferred automatically without the use of normal friction pads or plates seen in other limited-slip designs.
The Helical LSD differential's unique design offers maximum traction, improves handling and steering, and puts the power where it is needed most. A definite advantage, whether on the track or on the street.
The Helical differential is extremely strong and durable, and since it is gear-operated, it has no plates or clutches that can wear out and need costly and regular replacement. There is no maintenance required to the unit, so you can fit and forget.
The Helical differential is great for street driving or racing. Racers don't have to put up with locking mechanisms or spools that tear the steering wheel out of their hands when cornering. Because it behaves like an open differential during ordinary driving, street drivers will have trouble telling it's there until pushing the cars towards its limits.
The Helical differential is proven in everything from SCCA Rallying to drag racing and Formula 1. It provides autocrossers with such an advantage, it has become "required" equipment for a winning effort.
Expand your vehicle's limits with an Helical LSD Differential!
http://www.youtube.com/watch?v=vcSAiRxmm0w (this videos shows the benefit of having a HLSD, which is a type of torque sensing LSD, on a FWD car )
