On that car & miles, your TB is probably NASTY check the motorvate.ca site for info on it but if you clean it, remove it from the car to do so. Don't get lazy.
http://www.motorvate.ca/mvp.php/707
Your knock sensor is also probably toast. No CEL codes get thrown but if the codes are pulled 0304 will probably come up. It's a PITA to change and it is DIY and worth it. If you get no 0304 code, you're all set.
If you live in a rust prone area, check your radiator support bracket at the bottom of the radiator.
Your hood struts are probably on the way out too, so be careful with the hood staying up. Also a DIY replacement.
Lubricate your sunroof mechanicals where the cable runs down each side of the roof opening. Trust me, you don't want them to break. It's DIY to fix but takes a LONG time to do and you pretty much have to remove the whole interior to replce the cables.
You might also look at your spark plug tubes to see if oil is gathering in there. Especially the back 3. The seal in the valve cover is known to leak at that mileage on that year.
