Since I haven't seen one made, here goes.
H4 8000K HID kit
Phillips bulbs
I'll start with the driver side first.
Old bulb in
New bulb in
Cables connected to see if everything works
The best double side tape in the world
There is an obvious good mounting area for the ballast as seen below
Cables tied down and tucked away neatly
8000K HID on the left, Phillips bulb on the right
Passenger side ballast installation
Remove the fuse holder bracket with a socket wrench to make some space
Test fitting the ballast underneath the strut mount. It is a tight fit, but it is the best I could find
Everything installed, zip tied and put back in place
After results
I'll need to adjust the beam angle down to not blind everyone on the road at night. There really is nothing more annoying than a light brighter than the sun concentrated at you when it is pitch black everywhere else
I'll have pics once the lights have been adjusted. If it is still blinding, off they go...or projectors here I come
Modified by williamk10 at 12:24 AM 6/2/2009
