Ok got the pics for you, in the meantime i got my white LED's which i threw in my cluster instead of the blue ones, looks alot more high end now.
Drivers Side Headlight HID BOX:
Drivers side headlight, you just put in the bulb like you would with the normal ones. the wires just run out the back cause its slotted rubber.
Passenger side HID BOX
Passenger side headlight
Drivers side foglight HID box mount point
Passenger Side foglight HID box mount point:
and this is what the one foglight looks like how i did the wires on it, i cut a slot into the circle, pushed wires in small V or U shaped slot, i cut out on the edge, screwed it in and then sealed with silicone.
Now heres the HID Pictures, this is in my garage, it was still daytime but i had the doors and blinds closed so should be good enough.
Up top are 10k, and bottom is 3k. ( if you do get these hids, i reccomend those colors, also i would order them soon cause i noticed on top of their website, its a limited time special for the 43.99 price.)
and look what i found on this other SD card, these are from like 2 years ago detailing it, either spring or fall, probably fall.
But yeah there are the pics, hopefully they help you out
