j.hardstyle »
https://forums.nicoclub.com/j-hardstyle-u193508.html
Fri Jan 06, 2012 10:30 pm
No changes made except last week I put in a new FPCU and fuel pump. Thats it....but the problem just came up tonight.
I read over the LAN section in the FSM. I CANNOT get my car into the diagnostic mode. My lights are stuck on permanently, they dont flash etc. The ONLY way to get the lights to turn off is if I turn the left signal on. When I open a door then close it, the lights come back on and stay on.
IF I puse the signal with the key in the "on" position, the lights will stay off. So I then try to go into the diagnostic procedure for the BCM but it doesnt allow me to. I do exactly what the FSM says, but nothing happens. Either the lights never come on, or the lights come on and dont flash at all.
ALSO, my dome light has NEVER worked....all other lights work, even the two small lights attached to the dome light assembly work. But the dome light itself has never worked. So I dont know if this is causing the BCM to not go into diagnostic mode or what.
Dont know where to go from here. The lights no longer flash with the signal, they just turn off completely.....until the doors are opened again and then the lights come on and stay on. Doesnt matter which door is opened, once the lights are on, they stay on....not only the footboard lights, but the lights in the doors as well. I am sure the dome light would stay on if it worked.
