DON'T Downgrade from 4.2 to 4.1. Bad things.
4.2, in order to support the multi-user environment, alters the folder structure for a lot of things. It moves stuff from "/sdcard" to "/sdcard/0". Since this is the "internal" memory, it includes all your non-ROM files (pictures, documents, downloads, music, etc.). They get moved.
IF you decide to step back down to 4.1 (which I did) the OS can't find this stuff. I didn't even realize what had happened until I used Diskusage (one of my favorite apps, BTW) which showed me that I had a bizarre duplicate folder structure within a new folder called "0". A quick google led me to
this page at TWRP.
So I tried to use FX File Explorer to move the files, but I ran into a no free space issue for some reason.
MTP is also completely s*** and useless, and trying to copy large files just gives Windows a heart attack and doesn't accomplish anything.
In the end, I had to delete the downloaded "extra data" for some larger games to free a couple gigs of free space, which FINALLY let me start copying the folders back out of /sdcard/0 to /sdcard. Tedious and time consuming and a PITA.
Careful fiddling with 4.2 if you're not sure about your ROM's stability. If there's a chance you might want to downgrade, I HIGHLY recommend backing up your internal storage IN ADDITION to the usual NANDroid backup to be sure you don't lose anything. Normally I'm pretty good about this, but of course this was the one time I didn't.
