Fezzik »
https://forums.nicoclub.com/fezzik-u5572.html
Mon Sep 17, 2007 6:39 pm
Be sure to use a flathead with a cloth around the blade as to not scratch the trim.
1.) ON the 2000 maxima you have to remove the "bowl" (it has an outter lining to the door handle and is connected to a bowl) that the door handle is in. Its called the escutcheon.
2.) Remove the screw that is covered in the hand hold of the door (aka the door pull; the place you put your fingers in to close the door). The cover is obvious.
3.) Toward the front of the car on the door there is a door finisher. Located at the part that connects to the front dash when the door is close. Its round and covers another screw. Take this screw out.
4.) There is a slot in the bottom of the door that you can grab ahold of and pull the door out. Be carefull as there are wires still connected. I leave the door locks and window wires connected until i pull the door trim off and then disconnect everything. When pulling at areas of fastners of the door trim to the metal be sure to pull straight out and put your fingers around the fastner as you pull out to pull out evenly. you can tear up the fastners fairly easily.
Door trim is now off for you to get to your speaker. Lot easier to put back on.
