About a year ago I converted my hatchback to 5 speed and everything worked. Then I swiched my single cam for a twin cam and changed over all the parts and it runs real good. I changed over the rpm tach from one out of a twin cam and nothing. Everything works but I don't know what I'm reving at. There is no post that is clear or specific on this issue.
What gives signal to the rpm cluster the ecu or an ignition component?
Can the gauge be re wired directly to the distributor or place of signal without messing up?
I don't want to buy the huge 5" tach or something aftermarket, so is there a way to test the signal? Thanks to people who are brave enought to post and not just read and ask your self the same questions later on.
