I really need to identify these wires..
My alt isnt even hooked up to the harness and I dont have a plug that fits. The guy that owned the truck before me had this thing alllll jacked up!!
If I could get some help with what these are/go to it would be greatly appreciated.
The truck was running great until I turned on any electricals, it would bog down and misfire.. (Running lights, headlights, windshield wipers, radio)
This is a 1986 Nissan D21 4Cyl 2WD (I dont have an owners manual
Anyone know what this cut wire is? Also, Is the outer wire needed or can I just go ahead and solder it back together?
Here is a plug that is plugged to nothing. Not sure what it may be..
Here is a a random yellow wire with a black line and red dashes. (connected to nothing)
Also, wtf are these?! the bottom wire with the black tape is the bottom wire into that plugin.. top open wire is top wire in the plugin.
The white wire is, im guessing, the dash electricals. I hear the dinging inside the truck when I jam the white wire into the empty slot on that clip and touch it to the positive side of the battery. Also, my fuel pump kicks on.
