mattjdohm wrote:Hi there:
I hope someone can help me out. My 1993 Maxima SE (120,000 miles) makes one heck of a weird noise at startup. It sounds a little like a baseball card in bike wheel spokes doing a 'rattle' sound. It only happens on cold starts and only lasts about 25 seconds while idling. After that when applying gas it lasts maybe 2 minutes. After which it purrs nicely
Someone suggested it could be a timing belt: does that even sound plausible? If it is, is this a dangerous problem?
Thanks in advance!
Your Maxima has three timing chains -- no timing belt.
My best guess is going to be that your VTCs are in the very early stages of failure. It is extremely common with 92-94 Maxima SEs. It could also be your chain tensioners are going out, or a combination of both.
Do a search for "ve30de VTC" or "VTC failure" and do some reading.
There have been a few documented cases of catastrophic VTC failure, but it is pretty rare. The engine will make that noise and it will get more and more annoying. It is also quite expensive to fix.
