lmheim wrote: One post said the dealer told him that the engine tolerances are so tight on this model that a very small amount of excess carbon build up on the top of the piston can create noise like this.
doubtful.
As Heath said, the ring tolerances are loose on the VK45DE. But.....
Maybe it's all related: The carbon could create a local hot-spot, and oil getting past the rings will autoignite easier than the air/fuel mix (google LSPI).
As long as the bottom end is sound, at least 1 redline a week (fully warmed up engine of course) is considered good preventive maintenance.
