livinloud98 »
https://forums.nicoclub.com/livinloud98-u88399.html
Thu Sep 04, 2008 6:13 am
its very easy to do so, first thing you need to do is pop off the 3rd brake light, you push it toward the window and push it upward. Disconnect the wire from the 3rd brake light. Then fold all your seats down and pop out all the pins located around the area where the head rests usually sit. They go from one side of the car to the other, just get a flat head screw driver and use it as a lever to remove them, then you just simply lift the back panel off. There are clips and things that will pop as you take it off, so use some force in pulling it upward. but it will clip back on and wont break any thing when you put the cover back on. due to the seat belts you cant fully take that piece out of the car, i found that its easy just to pull the seat belts out to there fullest and put the cover where the trunk opening is. when your dont put the cover back on over the rear deck and just hit it a few times till you feel all the pins and clips go in. Replace all the pins you took out from lower part which you took out, and then replace and reconnect the third brake light. Its very easy ive dont it more then 3 times with installing speakers and wiring my spoiler bake light.
Good Luck, hopefully that helps you
