loystock »
https://forums.nicoclub.com/loystock-u10145.html
Thu Aug 05, 2010 6:20 pm
Your CV boot is broken. It's obvious from the picture that it's been leaking grease for a long time which eventually 'killed' the CV joint. A pair of CV boot replacement will cost you @ $350. more if you go to the dealership. The CV boots by themselves are inexpensive but it takes a while to replace those boots so labor charge is high. Since the CV Joint half shaft on that side is damaged (clicking noise), you might as well have both CV Joint half shafts replaced as the other side will likely fail, if not failing already. The total cost will be @ 500+, assuming they install refurbished half shafts, more if you want brand new OEM parts.
