MarkerZ32 »
https://forums.nicoclub.com/markerz32-u251973.html
Sat Jan 23, 2016 1:05 pm
A loud rapping that is consistent with engine speed during normal operation is usually indicative of worn rotating assembly parts. Unfortunately, the older Nissan fuel injection systems (long vacuum lines, multiple air bypass controls, long intake runners between the MAF and throttle bodies, lack of a MAP sensor, and just plain antiquated technology) causes most engines running on stock base mapping to run slightly rich. This causes the oil to degrade faster, especially if you have a heavy foot. Unless you're religious about oil changes and quality of said oil from the start of the engine's life (every 3000mi or less) that degraded oil will allow the rotating assembly to wear out the tolerances of all rotating parts (big ends, wrist pins, main journals, cam journals, etc.) When a tolerance is out of spec it will result in metal striking or grinding on metal which will only get worse no matter what you add to your oil. You could have an engine shop machine everything but it will end up costing you about as much as a ~stage 2 long block assembly.
But I'm more sure that your issue is between a rich condition (mostly attributed to the cold weather) or worn VTC gears/spring/piston.
