ADDirishboy »
https://forums.nicoclub.com/addirishboy-u94766.html
Wed Jun 15, 2011 10:44 pm
You don't need anything as large as an Armada, unless you have 7 kids. And lets be honest, you're not getting laid (without the help of chloroform, at least).
But back to the point, You need a new car because your "old" QX4 is showing its age? f*** you, you rich little prat. I've spent less than $15k on TWO different vehicles, and that includes all repairs and maintenance.
Buy an older Toyota truck. And by older, I mean pre-95. Buy something you can work on yourself. And adding gay tail-light covers and tinting your tails does not count as work. Get something you can learn to wrench on. When something breaks, pick up a f*** socket set and fix it your damn self.
We wouldn't rag on you so hard if you actually knew something about cars. Buy an older truck, fix it up, learn to appreciate something that you yourself worked on. Having mommy and daddy sign a f*** check doesn't teach you to appreciate a vehicle. Buying one yourself and then fixing it from the ground up does.
