s13_240_rb20 »
https://forums.nicoclub.com/s13-240-rb20-u87143.html
Fri Apr 24, 2009 4:24 am
hmmmm....since you have done a tranny conversion, I can't guarantee anything, but I'll start thinking out loud....
first guess: If you move as slowww as you can, does it still blow? Does it blow if you drive forward also? If it is idling, and it is pushed forward/back (while in neutral) does it still blow?? lol...you're gonna have to buy some more fuses, but these tests might just help you narrow it down to what components are involved...such as:
because of the tranny swap, do you have extra plugs/wires (not needed for a manual) that touch a ground source when the car moves?
if you push the car and you have it in neutral without pushing the clutch AND IT STILL BLOWS, then I would reeeaaaaalllllyy look into loose wiring/plugs, probably under the car swinging??
based on the testing mentioned above, are any specific components being used/engages/signaled?? neutral position sensor or clutch sensor (I'm sorry, I am half asleep if this isn't making sense, I can't think straight)...reverse sensor/lights if it only happens in reverse??
