I see, so it takes one to know one huh? oh wait... let me take that back. =PI feel better too lol, what you said was true, screw it up then you will learn real good.theother1wstolen wrote:your an idiot! and that makes me feel better, to know that im not the only idiot thats done this! im just messing with ya man, its not hard to fix once you know what to do, good luck, and the best way to learn is to **** it up the first time in my book :-p
With your method, you don't know if your on the COMPRESSION STROKE. You could very easily be 180 degrees off timing.theother1wstolen wrote:what i usually do is take a coat hanger, cut it, straighten it out, and stick it in the #1 cylinder through the spark plug hole (make sure the edge isnt sharp) then turn the crankshaft with a wratchet, and when the coat hanger is as high as it will go, thats tdc, then just set the distributor so that the rotor is is hitting plug #1. put the cap back on, your spark plug back in and you should be good to go.
Failure is a success if you learn from it right? =D
BTW thanks buddy rogoman, its really dark now, so I will try your method tomorrow.
I have one question about the ZERO thing and setting up a timing light.is there a picture I can see the ZERO you are talking about?
Now the pin is at the stock position.rogoman wrote:
Here you go:
