frapjap wrote:You ran through a good bit of diagnosing.
Have you done any checks to your ignition system? Coils may be slowly going out, or it may be time for new plugs & wires. At the least, replacing them wouldn't be a bad idea.
How are your O2 sensors? They could be sending something faulty to the ecu.
frapjap wrote:Glad to hear it, and thanks for posting your resolution!
You'll likely have to do the full valve cover gasket job in a little while, but you've at least got the knowledge and time on your side now.
Thx all. I was actually able to verify with my mechanic that I do have a rubber gasket, lucky me. However the saga with this continues when I got the quote to do the job. Got a good decent deal ($400) but my finances got a tight unexpectedly so I took the car back and its sitting in my driveway. Its probably a bad idea but im considering trying one more fix so that I can drive the car in the meantime. Im moving this coming weekend and I could use it since its wayy bigger than my 240 obviously. Anyway, Ive been backtracking the last several months to see if I could come up with some ideas. Not too long before all these issues I did a basic oil change which was the first id done since owning this particular Q. Found out in the process that it hadnt been changed in about 8-10 months of regular driving, eww. Car was running fine prior to the change by the way, merely trying to start a process of regular matinence. Searched around, and wasnt quite sure what oil to run so I changed it with some real cheap basic quaker state 10w-30 and the best filter I could source from wally world (fram premium high mileage). My logic was that fresh oil was better than what I had. My thinking here is that the cheap oil could be a possible source for the leak or could be speeding it up? Had a similar problem in my 240 and it cured it quickly. Its also been very hot here in Jacksonville over the last few weeks which doesnt help. Im thinking of changing oil again tomorrow but im gonna run 10w-40 mobil one full synthetic and possibly a bottle of lucas stop leak for insurance. Also run some seafoam prior to changing it to clean out some of the mess.mattd1979 wrote:Look in between the space of the valve cover and the top of the head and if you can, poke a small flat blade screw driver in there and see if it feels like rubber. Apparently if your car was built after February of 93 then it may have rubber valve cover gaskets.
Call me even crazier, cuz my next oil change will continue to be Mobil 1 0W-20. My Q is super quiet on the 0W-20 in comparison to the noisy 10W-30 I was using before that. Especially on cold mornings, the difference is night and day. Car warms up much quicker on the 0W-20 too. Which brand did you use btw?Infinitiguy19 wrote:Call me crazy but my next oil change I will run Mobil 1 15W-50. I have been running 0W-40 and once I ran 0W-20 (never again engine sounded horrible on cold mornings).
Infinitiguy19 wrote:Sounds like you need upper links!
I was gonna wait until I got home tonight but I think I may have jumped the gun on this. Got some advice from somone on another forum to just kepp trying to clean the injectors out. Like you he said the coils rarely fail also. Funny tho because my car surely has at least 3 replacement coilpacks. Anyway, I decided to use somethind different. Read up a little here at work, decided to try a bottle of techron which I have never tried before. 1 bottle, and $20 worth of gas, motor started responding within 10-15 mins of driving(my tank was close to E btw). I really want to close this thread but the Q wont let me!lolInfinitiguy19 wrote:I have never seen coil packs on a 1990-1996 Q45 fail. What kind of fuel injector cleaner did you use?
Blue devil stop leak may cause you some issues down the road. I would fix the leak no matter what it is rather than potentially clogging up something else.
What is the idle RPM's? I would be more inclined towards injectors. Did you check them?
No plug wires in 1997-2001 Q45. Has coil on plug ignition.frapjap wrote:You ran through a good bit of diagnosing.
You only use the Nissan Grey Spec RTV on the half moon part of the gasket (in the back). otherwise no rtv is used.marcyprojects wrote:frapjap wrote:Glad to hear it, and thanks for posting your resolution!
YES! Just when you think you know it all, something new happens. I do have one more question though. Im looking into neccisary parts for the valve cover gasket that I will hopefully takle in a couple weeks. Most what I read shows that our cars use RTV for this instead of a regular gasket. However, I have searched and found some regular gasket kits that say they are compatible. So far ive seen them on rock auto and ebay, the local autoparts places list the kit with RTV. Anyone shed any light on this for clarification?
