evildky »
https://forums.nicoclub.com/evildky-u13100.html
Tue Dec 23, 2008 8:05 am
some shops and some parts fo the country might cost a lot mroe or a lot less, but I had my block and heads rebuilt at a good local shop with a full gasket set for around $1200
the thing that I thnk throws most people off is the pistons, if you didn't destroy a piston you don't need new pistons, there are specialty Z engine rebuilders that sell blocks with forged overbore pistons, this adds to the cost of the parts as well as the machining, custom forged pistosn are about $1000 a set, less if you go off the shelf forged, and that includes pins, rings and locks and ifyou are going overbore or your cylinder walls are damaged you'll be looking at another $300 or so for boring
