Infiniti will only have records for the work that they did only. They would have no idea of maintenance being done by others, thus, you may want to go ahead and replace everything needed...
Per Infiniti the following needs to be replaced at 105k:
- replace oil/filter
- replace brake fluid
- in-cabin microfilter
- replace engine coolant
- replace spark plugs
Things that may have been skipped by previous owners were those needed via the 60k:
- replace transmission fluid
- replace differential oil
- replace drive belts
- replace transfer case oil
Form:
http://www.infinitig37.com/maint-sched.html
