First post here. Hope I can contribute some day, but for now I'm just a forum "user"
. I'm in San Diego.
Just got a nice condition, original female owner, 03 LE 4x4 for my son with 119k miles for $3500. She had every receipt since new. This was the 5th we'd looked at and needed none of the common suspension work that most seen to need. The only issue at purchase was a RMS leak (more on this below) that we negotiated the price down to include $600 repair.
Her recent repair receipt was for the P0021, for which she had the solenoids and one sensor replaced plus oil change ($1300 at dealer!). Here's the progression after our purchase -
Picked up truck, >100 miles from home. Before driving home wiped the pan and added Bars RMS.
At home (120 mi later), pan is slightly oiled, so added Blue Devil RMS planning to drive 150 miles then change the oil to spec (I'd read that the Blue Devil is more effective).
Within 10 miles got the first CEL and the P0021 code along with intermittent hesitation over 40mph. Started reading here and everywhere about this code. Also drove it another 100 miles and the leak almost stopped, just a little wet but zero drips. The RMS sealant seems to be effective.
Before changing oil to 5w30, I did try adding heavy Risolene to increase oil pressure, figure it was worth a try as the Blue Devil reduces viscosity and that is exactly when the code started, but the code continued.
Changed oil to fresh 5w30 "high mileage" Mobil 1 regular oil. Drove ~50 more miles, but code continued. I read how sensitive this engine is to additives*, so I changed the oil again to regular 5w30. Still getting the P0021 code, but not as quickly.
I pulled both the solenoids (very easy), checked operation, cleaned with carb cleaner, reinstalled. I'd thought the RMS sealant may have affected rubber parts, but there are none, just small screens, but they were already clean. Still getting the P0021.
Question - does anyone think changing the oil to 10w40 will increase the oil pressure enough and eliminate the P0021? I'd read on a Q35 forum that a blown internal gasket can reduce oil pressure to the cam shaft. Very expensive, hope that's not it.
* on the additives, hard to believe from my post, but I'm not into adding anything to my oil. I'd never had an RMS leak before, but I'd read how effective the RMS sealer can be, especially the Blue Devil, and it might save or postpone a $600 fix.
Thanks in advance for any help.
