Hello! Our KA-T Build.
RBmotorsports
Car: 1995 S14 240sx
Hello to everyone, we are brand new to the forum (Unless you count reading up about the S14)!! We would like to share some of our current project.
We got this 1995 S14 from a guy on C-list. He had already been messing with the car (and by messing I mean painting stupid things...) so we decided to correct all his errors first.
Last winter we pulled the engine, cleaned and coated it, had it machined, new internals, blanced crank, all that. Replaced the radiator with a nice unit, and adapted electric cooling fan. All the poly mounts got installed. We put the Z32 brakes on all 4 corners, and did some minor stuff like the steering wheel and hub.
This winter we are taking on the KA24det challenge. We are also about done with our circuit relocation (Relays, wiring, removing dead systems, battery where the blower motor and ducks went in the dash). We ordered our new intake manifold, turbo manifold, fuel pump and injectors. Much more is on the way.
Yep, thats it! Please give us some feedback, insights, and we are glad to be apart of this community!!
sx moneypit
Car: 2010 Nissan 370Z
1986 Toyota MR2
Welcome to NICO!Looks like a good build . :bigthumb:
-Ben
costa_rican13
Car: 1993 s13 coupe
not sure about all the red parts, and dont you think the battery is gona be a bit*h to replace when it goes bad being behind the dash? or are you guys not reinstalling the dash?
RBmotorsports
Car: 1995 S14 240sx
Its like 4 or 6 bolts, Not worried about it. We got it all powdercoated red last winter. We got the new intake manifold in, but idk about it.
We drive this thing when we want to, always in the heated garage. The battery has much life in it =)
300ZXttZMAN
Welcome to Nico!
RBmotorsports
Car: 1995 S14 240sx
So we finally got parts. =D T04E my baby...
So no problem on the install
Maybe a few =)
1.) So in relocating the relay box to the dash, Im concerned about the Power Probe readings. We decided to Kill our ground circuit. So why would it show 12.4 at chassis ground with the kill off?? It makes little sense that the 240 could be running circuitry without a ground? When the kill is ON, everything is normal.
Ill update asap. Things are movin, lets see where our 30k s14 goes!
RBmotorsports
Car: 1995 S14 240sx
No one? =( I have heard of Powerprobe doing this, just kinda sketchy.
300ZXttZMAN
I will never understand why people paint/powdercoat their oil pan..
RBmotorsports
Car: 1995 S14 240sx
Why not, its nice. and it was hulk green...
Anyways here's some more pics.
Everything is fitting pretty nicely.
Dash back in. Was super easy to remove/install it tho.
Screw it.
About all done with the switch board. Need to finish the top piece tho.
Battery chillin.
Early pics of the turbo mock up.
RBmotorsports
Car: 1995 S14 240sx
Hey! So its been a busy week, but were chuggin along.
Got the injectors today. Just waiting on our intake piping.
Question:
Is the coolant to the throttle necessary? I freaking hope not.
All torn back down again. Looks good tho =D
The turbo getting all its fittings ready.
The shop. Nice and warm!
Another angle.
PITA. Worst part about this is the return. Whatevs
Oil feed and pressure monitoring manifold.
biggie
Coolant to throttle body? No not necessary, most bypass it.
RBmotorsports
Car: 1995 S14 240sx
Excellent. Didn't wanna run the hoses because of the new intake mani and heater core bypass. Thanks
S13_RB25
Car: A 240 but no RB yet!
Nice build! Looking good so far. How much hp you trying to get out of this?? Also ive heard lots of bad stories about frame oil filters on Nissan's, just thought let ya know, don't want all that going down the drain just cause of a $5 part!:)
RBmotorsports
Car: 1995 S14 240sx
Ya, I heard FRAM uses a paper element that fibers fall off of blah blah. Not sure if its really a huge issue. Just got back from a mini vacation. All the piping came in. Gotta figure out a smooth way to mount the intercooler.
HP wise, were looking for around 275 or so.
Ill be over there later re-sealing the front cover and oil pan. Ill do some photoshooting.
CJH
Car: S13
Nice job so far. Might be a bit of over kill if you want 275, but it should do the trick :biggrin:
RBmotorsports
Car: 1995 S14 240sx
=D
So I decided to refurb the fuel rail because its all corroded and everything else is brand new.
Looks good. We were planning on a new rail, but screw it for now. Too much to do..
Looks really nice tho. I hope this doesn't interfere with fuel temp.
We also installed a MrGasket fuel pressure gauge inline.
So we were arguing about the routing of the wastgate/BOV/boost controller. I was wondering if anyone had any diagrams or nice pictures or insights to this.
BOV goes on the cold side, and gets vac and post-throttle?
Wastgate goes to the boost controller and then to vac?
I know I know search, but I really dont want to hack up the intercooler piping and mess all the nice bungs up.
RBmotorsports
Car: 1995 S14 240sx
Had a little time, check this out.
No problem.
Relocated that real quick.
Intake electronics.
Lets start her Friday =D
