REMOVAL
1. Remove undercover with power tool.
2. Drain engine coolant from radiator drain plug at the bottom of radiator, and from water drain plug at the front of cylinder block. CAUTION:
o Perform this step when engine is cold.
o Do not spill engine coolant on drive belts.
3. Remove air duct and air cleaner case.
4. Remove water drain plug on water pump side of cylinder block.
5. Disconnect radiator hose (lower) and oil cooler hose from water inlet and thermostat assembly.
Remove water inlet and thermostat assembly. CAUTION: Do not disassemble water inlet and thermostat assembly. Replace them as a unit, if necessary. INSTALLATION Note the following, and install in the reverse order of removal.
6. Remove water inlet and thermostat assembly. CAUTION: Do not disassemble water inlet and thermostat assembly. Replace them as a unit, if necessary. INSTALLATION Note the following, and install in the reverse order of removal.
o Be careful not to spill engine coolant over engine room. Use rag to absorb engine coolant.
source:
http://my350z.com/forum/engine-and-driv ... q35de.html
If you need help bleeding the cooling system.. PM me and ill walk you thru it.
