Jostudly wrote:I have a 09 Rogue and noticed that my heater takes awhile to heat up but does not give a lot of heat even when warmed up.
From Canada
kerrton wrote:I find the heater in the Rogue very weak, even at the best of times the engine takes a very long time to heat up and even once it reaches operating temp I find the heat is just barely adequate.
From Canada
Qashqai wrote:But I should say Rogue's heater/AC is the worst when compared to the ones that I drive.
From Canada
i gotta re-reference back to my prior post:
i know some of you folks live in Canada, and maybe your mechanics up there are actually doing the opposite, of those mechanics that decrease the amount of anti-freeze. I know that Canada hits some seriously low temps, and the last thing you want is to ruin your engine because of poorly mixed water/anti-freeze by not having enough anti-freeze, but having MORE anti-freeze will cause your heater to not be able to blow hot air. Call your dealers if your from canada and find out what ratio they use. if they do use MORE anti-freeze than water in their ratio, well then there is your problem.
I guess their mentality is: since our temps are so low, we dont need as much cooling protection(water), as you would need freeze protection(anti-freeze). that will certainly diminish your heater core temps = resulting in poor heating properties.
positives:
water: has a great conductivity rate. it cools fast, and heats up fast. low boiling point
anti-freeze: doesnt freeze as easily, doesnt heat up as easily either! lubricates the water pump & nourishes the seals. higher boiling points
negatives:
WATER: having to much water wont lubricate the water pump, wont nourish the seals. will freeze quickly, and will heat up quickly(due to low boiling point). if not cycled fast enough by a reactive thermostat = you could boil & over heat. but because it heats up quickly, it will heat up your engine faster, and will bring more heat to your heater-core, more often, quickly.
ANTIFREEZE: doesnt absorb heat as well, so takes longer time to heat up. that means it will take longer to heat up, thus taking longer to heat up the heater-core, thus requiring longer intervals before fresh hot anti-freeze is brough into the heater core to replace the cycle that cooled down already. (that means air wont be warmed enough before it exits through your air-vents)
so if you live in the cold north, you have to think about what temps you guys face. do you really need more anti-freeze or could you skimp by 10%-15% and get away with it? you gotta see what your winter temps are and see what you wanna do. IM ALSO INCLINED TO SAY THAT THE THERMOSTATS YOU GUYS HAVE UP THERE ARE DIFFERENT THAN THOSE IN THE USA.
a simple and quick example: drain out about half a gallon from your radiator via the drain plug. replace with half a gallon of distilled water. see what happens! give it a couple days to mix the water & coolant together. result wont be immediate. let the fresh water and what was in there before time to co-mingle and spread out between the cycles. if the results are not what you want, simply drain out a quarter of a gallon and replace with 50/50 mix.
