The00Dustin »
https://forums.nicoclub.com/the00dustin-u137235.html
Mon Oct 05, 2015 3:09 am
A vented seat is a seat with perforation (vents). A ventilated seat is a seat with a fan to blow air through the vents. A cooled seat is a seat with additional cooling. Unfortunately, when it comes to heating, there aren't different terms that I'm aware of. Even when it comes to cooling, not every manufacturer properly uses these terms (I was in a JEEP Grand Cherokee rental not too long ago that had ventilated seats, but the controls called them "vented").
In spite of some comments to the contrary above mine, the 2006-2007 M series has a cooled (and heated) seat. I don't know about newer models, but I would expect them to as well. To be more specific, the TEC plate is a thermoelectric plate that is a type of peltier element, and it does cool and heat. A peltier element gets cold on one side and hot on the other when current is run through it. The direction of the current controls which side of the element changes temperature in which direction. Unfortunately, instead of having nice heating elements like heated seats used to all have, the heated seat is created by reversing the flow of electricity on the TEC plate (which is why the fan still runs for heating the seat). The fact that both are not working probably implies a problem with the TEC plate, which I would hope could be replaced without replacing the entire seat. It may even be possible to clean it instead of replacing it. Before trying any of that, though, does the passenger seat one work? If not, the issue could be elsewhere (for instance, a blown fuse, although blown fuses typically indicate bigger problems). For that matter, even if the passenger side does work, it wouldn't hurt to check for a blown fuse before paying anyone else to look at it.
ETA: Re-read the OP. If it works again the next day, it's obviously not a fuse. Odd that the problem only occurs with heating and not cooling. Not quite as odd that a "reboot" is necessary to "fix" it. However, given that the two modes should use the same amount of power, perhaps it's a wiring issue at the switch?
