pweroptions wrote: We have never had a problem with this car until this.
Impressive! 16 years, and no problems--that's '90s Japanese engineering for ya.
OK, sounds like qship 96 called it, I have a few related thoughts:
if your R-134 system is slightly low, the evap can run colder than freezing and might be frosting because of it.
extreme ambient low temps may play a part.
I believe defrost mode will always run the compressor.
you might modulate between defrost auto and floor/chest econ mode as a stop gap.
Heath may also be onto a bad sensor on your evap.
suggest a full hard pump down of the R-134 system, add 1 oz of PAG-46, change your drier (just because after 16 years), and refill with the prescribed 750grams of R-134.
