What do you drive? If you've got a 2001+ QX4 a major possibility is the switch. If it's what happened to me it will get worse and eventually start happening to the other side.Sizemore wrote:So tonight I'm driving and I notice my drivers side headlight is blown out. It happened once before, but I turned off my lights and turned them back on again several times and it somehow worked itself out. Haven't had a problem since..
..until tonight. What's weird about the situation is that the light works perfectly fine whenever I turn my highs on.
Is this just a simple problem with the bulb or is it a bigger problem with the fuses (as a friend of mine suggested). And also, is it normal for bulbs to do this?
It's a 2001 Pathy, for the record. But if it is the switch, where exactly is the switch located?Empty V wrote:
Billy
Yup that's it. It's extremely easy to replace. I'm pretty sure it's a few screws and connectors. Takes a whole 3 minutes. I got a new switch form the Infiniti Stealer for about $80. Like I said I was having what sounds the same issue which progressively got worse. Eventually both of my low beams shut off while driving. Kind of freaky on the busiest freeway in the US @ midnight.KyooX4 wrote:I believe they're talking about the stalk besides the steering wheel, that you twist to turn the headlights on and off.
Courtesyparts has a DTRL control module on their site (http://www.courtesyparts.com/28576-cont ... 00278.html), but I wasn't sure it was the right one for my Pathy. I bought it anyways, and when I was entering my address and payment information, in the comments field I gave them my VIN and asked them to check the part number against the VIN. Sure enough, I ordered the wrong one, but they replied back and told me they'll substitute the right one instead.gr84u2009 wrote:Hi there, I'm having the same problem with my 2003 pathfinder. Went to the dealership and they diagnostics came out with a defective module. Can you tell me or do you know where I can find the step by step to replace the unit myself.
As well, the dealership wants ~$400 for part and labour, noticed courtesyparts has it for $130. Will this work on my Canadian vehicle?
Your help is appreciated.
You should have just halogensSizemore wrote:It's a 2001 Pathy, for the record. But if it is the switch, where exactly is the switch located?
It's beside the battery, on the passenger side wall of the engine bay. Should be a beige box, maybe 4"x3".techracer wrote:So where exactly is the headlight control module? my wifes passenger side low beam has been out for about a week, went and bought new bulbs, no go. I'm thinking it's probably the headlight control module after reading this thread.
For the record, we have a canadian PF with the DRL's so Densetsu's fix will hopefully work....
Modified by techracer at 10:12 PM 11/8/2009
Sorry, missed your previous post on Nov 13, but glad that it fixed your problem.techracer wrote:So I went out on a limb and ordered the part you gave for Canadian PF with DRL's and after 2.5 months of back order i finally received it. Took me less than 10 min to swap it out and BINGO, I've got both low beams again.
Thanks so much for all the help.
Hey, thanks for sharing.mikedee4 wrote:Hi Buzzman,
Courtesy parts sold it for $144 and $15 shipping. I live in Hawaii so not much chance I'd find a part unique to Canadian Pathy in the junkyard.
