Neejay wrote:Well it sounds like it would make sense...if I knew anything about electronics...what could I use to test it?
Well, I tested my washer pump this way (extra washer pump):
I got some gauge wire, I think I used 12 gauge, but you probably want something smaller to prevent short circuiting your stuff - o yea, be careful not to do that
Well, just connect up some wiring, and either splice it, or take out the connector and manually run wires or make a connector (like the slide one - not sure what it's called) to the motor and then to the battery.
The motor should start moving up and down continuously.
If it is, then your motor is fine and it is something to do with your wiring somewhere (I would have no clue where to begin with this part).
At least you know your motor is ok.
ANOTHER THING:
If you get a multimeter or voltage tester, you can take apart the driver's side kick panel and test the correct wire for activity when you turn on and off the headlights, which tests the signal to the motor.
The wire color itself is long out of my memory but I'm sure someone can help you with this.
