Thorshammer wrote:Is there a reason you choose not to show the before and after pictures of the same headlight?
It helps to see the before and after pictures of the actual headlights you cleaned. Pictures of two different headlights don't tell the whole story.
i happen to come across this same issue at times, when i get to work and start thinking i should turn this job into a forum write-up, and THEN realize that i "should have taken a before picture". so i end up simply taking the opposite part for comparison.
