86 720 »
https://forums.nicoclub.com/86-720-u144276.html
Tue Apr 13, 2010 7:43 pm
Headlight housing I bought off of ebay for $16 each. They are 4x6.5 and fit in the headlight surround trim nicely. Notice they are crystal clear, looks much better than sealed beams.
The back of the housing unit. The bottom wires are for the 194 lamps that make the headlights turn blue. These are pigtailed together, positive to positive and ground to ground. They are than run to an LED switch inside the cab with a fuse.
Since I abandoned the stock wiring harness in favor of larger power and ground wiring(for HID), I had to have larger pigtails as well. The parts stores only had 16 or 18ga. pigtails, thus I had to order out some custom made ones. The ones on the left(long tube) are incorrect. The H4 HID I got from DDM came with 9006 male sockets(far right) instead of H4 sockets. These are custom made from an online store using 14ga. wiring. You can have them shipped in pieces for the extreme DIYer or pay an extra 0.50 cents per pigtail for assembled ones.
The lo/ho beam switch grounded the signal when hi beams are to be activated. In order to save the contacts of the switch, a master headlight relay was added. Then another to switch from lo/hi beam
The electricity flow has been highlighted to show Lo beam flow through the circuit:
The electricity flow has been highlighted to show Hi beam flow through the circuit:
The relays were placed under the dash behind the steering wheel. I placed them inside the cab for better protection from the dust here.
Final result: H4 headlights, only the passenger side. Please note the car was leaning to the right as the roadway was dipping that way.
H4 HID single lamp: These are 6K HIDs so they are a little blue, however they have not completely warmed up to their true color yet.
Dual headlights, still not completely warmed:
After they have warmed up and at operating temperature.
Although it's hard to tell in the photo, once they headlights have been properly aimed, they provide MUCH better light output, and throw the light further.
I have to give credit to my friend and fellow Datsun enthusiast Ben510 for doing a lot of the work here, and for coming up with the wiring diagrams
Modified by 86 720 at 10:49 PM 4/13/2010
