Oh but there are 55w bulbs.. but no not from reputable manufacturersIlyaKol wrote:There no 55w bulbs...only ballasts. All bulbs are 35w. At least from any of the reputable HID kit manufacturers. So all you need to do is replace your ballasts...and that will make your 8000k 35w bulbs look more like 6500 or 7000k which is better (but not the best).
For a truly potent system, go 55w ballasts and 6000k bulbs. That will make the bulbs look more like 5000k which is very good but also gives that little blue hue that people know and love from xenon lights.
I appreciate the informative reply, I have issues driving at night and would love to upgrade the bulbs.Larz wrote: I now have Phillips 6000k which put out 2800 lumens when new, so the Osram CBIs will increase brightness (and therefore distance and width) by an additional 2200 lumens. Thats 55% brighter and sharper than my current bulbs!
So I was about to order the D2S Morimoto XB35 6000k bulbs last night for my 07 M35, but then I thought let me wait and see if they give a discount to dealers. Good thing I did because apparently all Morimoto D2S bulbs are incompatible with stock Infiniti HID ballasts. The gentleman I spoke with at The Retrofit Source said that the Morimoto bulbs do not work or fail on at least 80% of cars with stock Infiniti ballasts. He said you have to get the Philips or Osram. It sounded a bit like an upsell, but the gentleman was extremely friendly and even said I could get the bulbs from the dealership (but at a higher price). Plus, he told me about their wholesalers discount program, so I think the information is genuine. Which leads me to...DJPlayedYA wrote:I noticed on some listings for bulbs on TRS, it gives a warning NOT to use the bulb with a stock Infiniti ballast. Is this warning just to cover their arses or are you really not supposed to use an aftermarket bulb with a stock Infiniti ballast? Thanks in advance.
good call...my buddy who does a lot of mods on cars said the same thing...he pointed me out to the V-Leds site and showed me where they even give a warning to Nissan/Infiniti owners about using Morimoto bulbs with OEM ballasts...I've included the link.... I chatted with RetroFit and they indicated that Vleds get their Osram bulbs directly from Retrofit...so we can trust Vleds as well.DJPlayedYA wrote:So I was about to order the D2S Morimoto XB35 6000k bulbs last night for my 07 M35, but then I thought let me wait and see if they give a discount to dealers. Good thing I did because apparently all Morimoto D2S bulbs are incompatible with stock Infiniti HID ballasts. The gentleman I spoke with at The Retrofit Source said that the Morimoto bulbs do not work or fail on at least 80% of cars with stock Infiniti ballasts. He said you have to get the Philips or Osram. It sounded a bit like an upsell, but the gentleman was extremely friendly and even said I could get the bulbs from the dealership (but at a higher price). Plus, he told me about their wholesalers discount program, so I think the information is genuine. Which leads me to...DJPlayedYA wrote:I noticed on some listings for bulbs on TRS, it gives a warning NOT to use the bulb with a stock Infiniti ballast. Is this warning just to cover their arses or are you really not supposed to use an aftermarket bulb with a stock Infiniti ballast? Thanks in advance.
...Have any of you guys tried aftermarket (basically not Philips or Osram) bulbs in your stock Infiniti HID ballasts? Does it work perfectly? Thanks for your input.
