Klajdi1985 wrote:ken in az how are you getting 19.1 mpg in the city, please man let me know all you have done to yours because mine is stock with just an injen cold air and im getting 13.8, im very dissapointed with that number..... help me out man. thank you.
I wont spend a lot of time on the mpg topic but I can gice you some advise:
1. go to ecomodder.com Read the sticky on 'the 100 things you can do to get better MPG'. 90% of the mods done on this site are tested a-b-a. So they can factually show it works to improve mpg.
2. Cold Air Induction will never improve mileage. Basic physics. Warm air inproves mileage. Go to the site. type in cold air induction.
3. The trany ecu can learn how you drive and sets up the shift patterns accordingly. You would need to unhook your battery for awile to erase and start clean.
4. next time you buy tires look at a slight increase in diameter.
The 02Q45 Sport came with 18x7.5 rims and 245/45/18 rubber.
I run 255/45/18. I also run nitrogen instaed of air. keeps the tire at a constant psi reguardless of the temp.
Add I run 39 psi. When I travel, I go by the Tire sTORE and get bumped up to 44psi
5. You gatta do what you are comfortable with. I decided when I got the 02Q45Sport in 2005 at 40k, that I wanted to run to 250,000. I drive easy and do maintanace religously. I also do the eco mod that I am comfortable with.
