leadpig »
https://forums.nicoclub.com/leadpig-u200992.html
Thu Mar 22, 2012 1:37 pm
Same thing just happened to my 09 sedan. Luckily a few K and just a month before warranty expires. Went to dealer but the failed part is in the passenger door (because drivers door unlocks solo on one hit of the key, press remote twice and all other doors plus trunk unlock and the electronics controlling this are in the passenger door). When describing the problem, the tech at the dealer finished my sentence - knew exactly what the problem was and where to look. Took very little time to diagnose so clearly this is not a rare problem. I suspect there is a TSB for this but have not looked for it since mine was covered under warranty. Since you are so close to warranty it is worth going to the dealer and seeing if they'll help you. No guarantees but worth an ask.
