I might be too late, but tighten it, NOW! Don't rev it, don't even start it until you've done so. A slight wobble like you describe has ruined the keyway in my crank (and as such, the crank as a whole), the keyway in my balancer, and the timing gear. And the woodruff key, of course, but that was the least of my problems.Dan1200sss wrote:My harmonic balancer has started wobbling at idle in the last 1000 or so Kms, wobbles quite a bit at idle but if I hold revs up over 2000/2500 Rpm it doesn't seem to wobble anymore or no where near as much anyway. What you guys reckon ? Maybe the rubber inside of the harmonic balancer has started to break down or something? My bottom end assembly is aftermarket balanced if I do get a brand new pulley/harmonic balancer and fit will it cause any damage because it's not balanced to the rest of the rotating assembly ?
