Hard wiring o2 sensor - need reassurance
trevr
Car: '07 Mitsubishi Eclipse V6 swapped supercharged
'93 Nissan 240SX Vert CA18det **SOLD**
Engine harness to Bosch Oxygen Sensor 13276
Brown -> Red = PowerBlack -> Black = GroundBlue -> White = Signal
http://www.autozone.com/autozo...Bosch
dhen
Car: MGA w/ CA18DET
I have a universal O2 sensor from Auto Zone. It has three wires, but only two colors. The two that were the same color are for the heater, and I don't think it matters which way you wire the heater wires. The CA sensor wire is thicker so you can't really go wrong.
Worked for me.
float_6969
Yea, you're right. Either you'll have 2 wires the same color, one to ground, one 12v+, or you'll have a red and a black. red = 12v+, black ground.
trevr
Thanks guys!
dattodude
Car: CA18DET Datsun 1200 B110 Sedan
wire colors sound ok.
but good quality o2 sensors use stainless wire into the sensor.you can only silver solder it or crimp it onto connectors.
good luck.
