Haltech Platinum 350z pnp Standalone EMS
Nissan 350z / Nissan 370z general community discussion forum
turbo6
Car: '05 350Z Turbo, '98 SC300 9.3@156, '99 SC400, '02 Police Interceptor
Injected Performance is proud to announce the arrival of the Haltech Platinum series Plug and Play EMS for the 2003-06 Nissan 350z. After months of testing, the newly designed Platinum series EMS is ready for the Nissan 350z market. We have worked closely with Haltech and are now able to offer, as the US DISTRIBUTOR, the Platinum PnP EMS. With features that no other current EMS on the market offers, we feel all your tuning needs will now be taken care.
Some Key Points for the Platinum PnP EMS:• End User Tunable (not locked like some EMS on the market)• Sequential Fuel and Ignition Control (32x32)• Cylinder Trim Tables for each injector and ignition coil (8x8)• Coolant and Air Temp Correction for fuel and ignition• Complete Intake and Exhaust Cam Control (03-05’ Intake Cam control only) (24x24)• Configurable Load and RPM points for all tuning tables • Tuning via MAF, TPS, or MAP• Fuel tuning by Volumetric Efficiency (VE) or Injection Time (MS) • Injector drivers operate both Saturated and Peak & Hold injectors• Map Trace• Knock Detection• Overboost Protection• Open/Closed Loop Boost Control• Dual Closed Loop 02 Control• Onboard Data Logging• USB Communication (no outdated Serial cable required)• New Windows Tuning Software, ‘Haltech ECU Manager’• 32Bit Microprocessor, 55MHz• Plug and Play Loom• Auxiliary two-step rev limiter• User Configurable Inputs and Outputs (coming soon in a free software update)• Nitrous and Meth Injection Control (coming soon in a free software update)• Knock Control (coming soon in a free software update)
In your Platinum Series PnP EMS package you will receive the following:Haltech Platinum Series EMS with onboard MAP sensor and onboard data loggingPlug and Play HarnessUSB connection cableSoftware and User Manual on CD
Retail $2299
IN STOCK HERE
radoman93
bump
bkreitzer
Car: 2007 Nismo - Redline - #0550 - more info in my Bio
GREAT!!!
Create this for the ‘07+ and I will buy one! I think that is will take some time to complete, which is a good thing because I need to start saving!!!
_jb
Any other Haltech users here?
It's a great engine management system...
panapower
Car: 1993 sentra, 1998 Acura gsr, 1965 mustang
_jb wrote:Any other Haltech users here?
we've used the haltech on other cars like a SC'd alfa romeo and an fc with a turbo b13 pushing out 460+whp. the new software is MUCH MUCH better and we'll be getting one for one of our customers with a turbo 350z as well as our own car a 200sx with an sr20det.
shiftlock 350z
Car: 2004 Nissan 350z
Hopefully this will get people to quit wasting money on utec crap
CHORAY911
Car: 96 MAXIMA, W/VQ30DEK &TO4E Turbo, 13" 300ZX Brakes, 10" TV in the dash
I'm about to drop a vq35de into a 4th gen Maxima with a to4e. Has this unit been tested on the 2002 up maxima with the vq35?
turbo6
CHORAY911 wrote:I'm about to drop a vq35de into a 4th gen Maxima with a to4e. Has this unit been tested on the 2002 up maxima with the vq35?
I checked the 02/03 Maxima VQ35, and they use a different wiring harness so it would not plug directly in. You could wire it, or look at using a 350z harness.
rmezz13
Car: Had 2004.5 Nissan 350z
Have 96 f250 and mommas 07 Murano
shiftlock 350z wrote:Hopefully this will get people to quit wasting money on utec crap
have you used UTEC? what is wrong with it or what have you heard? i have heard all good and its #1 recommended. please inform me before i buy!
CHORAY911
turbo6 wrote:I checked the 02/03 Maxima VQ35, and they use a different wiring harness so it would not plug directly in. You could wire it, or look at using a 350z harness.
I would be willing to do that, I'm not afraid to cut up a harness. Do they have the same sensor connections? I would have to get the FWD block and use the RWD harness.
turbo6
CHORAY911 wrote:I would be willing to do that, I'm not afraid to cut up a harness. Do they have the same sensor connections? I would have to get the FWD block and use the RWD harness.
I would assume they used the same connectors, but I have not tried this personally to know. My only other concern would be the length, you may have to open a bit of the back of the harness to make it come through the firewall at the appropriate place. Otherwise you can use the stock harness and cut into it inside the vehicle where the ecu is.
Anthonysflying
Car: 2004 Silverstone 350z Touring
What a dream come true
car-parts-happy
Car: Datsun 240z
Anthonysflying wrote:What a dream come true
Agreed thanks for the car parts. Should be used by myself in the next few months
drews240
Car: 240sxGT racer, 300zx NA custom, 2000 frontier,76 Corvette Stingray, 2004 MAzdz 3 GT.
Haltech platinum is an incredible unit, we recently installed this in my 2005 Infiniti G35 coupe pulled out 260.9 WHP on a bone stock motor in 1 hour on the Dyno. I have been racing this car in select GT races and the local Time Attacks and it has been amazing. Thanks to Injected for their help
Drew http://www.anothershade.com/racing.html
Return to “350z / 370z Discussion”
