It's not too bad. What about the ride difference?TDot wrote:It dropped the exact amount they said it would, 1.5".
Oddly, seeing the picture makes the difference stand out. There doesn't seem to be that much difference when looking at it in person.
I'm not quite sure what you mean about the damper. I though dampers were a principle of the struts. The springs rate seems great. They are soft when they need to be, and hard when they need to be to keep the car riding smooth. There are points where I swear they should bottom out but the spring rate is just right to prevent it. All of that taking in to consideration my perception and driving habits will be different from yours. Rebounding from a compressed state happens very smoothly.fat3oy wrote:how is the damper and spring rates tdot? I'm considering selling these over eibach - and do not have a set handy.
I kind of think its better than it was. But I don't know if its because of the springs or the struts are new. But taking the bumps seem a little smoother and softer...not like Lexus, but better than it was.svard75 wrote:What about the ride difference?
So then I won't experience a sag because of a full tank? Cool.jiggersplat wrote:The spring rate should be higher than stock.
That's weird... you wouldn't think the rear would be any heavier... the front I understand, but rear?TDot wrote:No bueno for the rear springs. I guess the rear on the X is way heavier than the base model. And the tank is a little less than half full smh. I think I have about 40-50lbs in the trunk and this isn't even settled, about 20 min. after the drop.
I guess I got to put the stock back on the rear.
svard75 wrote:Hey fatboy, what makes you think the rear of an AWD is heavier? The transaxle is in the middle and front axle, diff in the front. I guess the transaxle adds a bit but then again our drives haft is shorter too.
LOL. Wow TIEN support is brilliant. Preload is for a coilover setup not a spring by itself.TDot wrote:Tein told me it's like this because I didn't preload it first. I don't understand how that would change this because it's simply the spring sitting in a perch.
This is what they sent me: http://teinusa-blog.com/applying-suspension-preload/
I simply raised the perch back up and aligned it to put the bolt through like everyone else. I've never seen anything anywhere else about preloading independent spring and strut. Opinions?
Edit:
I looked in the FSM (pg 15 of RSU) and it says nothing about preloading the rear, as far as I understand it at least.
Is the lower link the spring perch?
