Gold Digger »
https://forums.nicoclub.com/gold-digger-u15335.html
Tue Feb 11, 2014 6:41 pm
Are you talking the dash piece that is all one piece from the bottom of the radio all the way around the main cluster?
If so, I can help.
FIrst off, lower your steering wheel to the bottom, then remove the upper and lower steering column covers. Should be 6 screws, one of which is above the tilt steering lever. Doing this step isn't necessary, but it makes removing/replacing the dash panel much easier.
Next, remove your shifter knob and pop out the shifter cover/boot piece. Just pops out with just a little pull from the back of the cover. You'll need to remove the plug for the cigarette lighter so you can move the cover out of the way. After that, remove your ash tray.
There are two screws under the shifter cover and two screws behind the ash tray. Once those are out, very carefully pull the bottom of the center dash panel. It will just pop off. Then work your way up to the top by the center vents then around the part of the dash under the main cluster, but don't try to pull the dash out of the way.
Once you have the dash pulled off, you'll need to reach behind and unplug the power mirror control on the right. You'll also need to unplug the rear window defroster, the hazard blinkers and the clock. There is also a small plug on the part that goes under the main cluster where there is a hose below it. It's kind of tricky to get to these plugs, but you can do it. Also, it's easier to remove/replace the dash panel if the driver side door is open.
Once you have that done, you're home free.
Now, if you're talking the center armrest consel, follow the step for removing the shifter boot then open your center storage compartment. There are 4 screws in the base of that pocket that need to be removed. I can't remember if there are any screws at the front under the shifter cover.
Hope this helps!
