Green LED on seat controls flashing
LEMHEAD16
Car: '12 Genesis Coupe
'95 QofDOOM
'56 Chevy pick up
The green LEDs on the seat "1" and "2" buttons flash constantly about once per second. The only way to stop it is to disconnect the battery and then the flashing goes away but eventually returns.
Any ideas?
N/A Q45
Car: 94 Q45
LEMHEAD16 wrote:The green LEDs on the seat "1" and "2" buttons flash constantly about once per second. The only way to stop it is to disconnect the battery and then the flashing goes away but eventually returns.
Any ideas?
Did you try hitting the cancel button on the steering column.
qship96
Car: 1996 Infiniti Q45
that has nothing to do with it.
N/A Q45
Car: 94 Q45
qship96 wrote:that has nothing to do with it.
Well it does actually. If you hit cancel then the seat memory and steering wheel memory doesn't activate!
So that would almost. .. almost make me crazy enough to think they are connected :lolling:
qship96
Sorry,once again you dont know what you are talking about.....becoming a repetitive theme with you.
N/A Q45
Car: 94 Q45
qship96 wrote:Sorry,once again you dont know what you are talking about.....becoming a repetitive theme with you.
So you're saying that if you hit cancel the seat/steering wheel memory still works and is activated??
-lol-
LEMHEAD16
'95 QofDOOM
'56 Chevy pick up
Cancel on the steering wheel cancels Cruise Control. I just confirmed that it does nothing to fix the flashing lights.
qship96
I am saying the position of the "cancel button" HAS ABSOLUTELY NOTHING to do with the 2 green lights flashing.....everyone,but you,already understood that.
qship96
was referring to the cancel button that stops the steering wheel from moving when you insert/remove the ignition key
N/A Q45
Car: 94 Q45
LEMHEAD16 wrote:Cancel on the steering wheel cancels Cruise Control. I just confirmed that it does nothing to fix the flashing lights.
Other cancel button
N/A Q45
Car: 94 Q45
qship96 wrote: was referring to the cancel button that stops the steering wheel from moving when you insert/remove the ignition key
(edited)
Anyways though.. this really is not spose to be about anything other then what the OP asked.
So for the hell of it just hit the cancel button on the column for the two tenths of a second it takes just to see if somehow it makes a change is all I was suggesting.
qship96
stupid suggestion,thats all I was/am saying.Proves how little you really know about the basic operation of the vehicle.
goody90q45
Car: 1992 Infiniti Q45 (sold)
Try this and let us know if it works.
1. Open the drivers door
2. Turn the key to the Run position
3. Turn the key all the way back off, but don't remove the key
4. Close the door
5. Wait about 1 minute
6. Open the door, the memory function should work now.
If the light quits flashing you'll have to reprogram the seat position memory.
Q451990
N/A and qship - I cleaned up this thread... Please keep it as civil... downright name calling isn't what we're looking for here.
Heath
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
N/A Q45 wrote:
qship96 wrote:That's why I have the fastest N/ A Q45 :slap:
Even if that were true, it proves nothing. Learn or burn.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
In the EL section there's a self-diagnosis for the Automatic Drive Positioner, which controls the seats and all that other fun stuff.. I've seen this happen before, so the self diagnosis is a great place to start.
Start on EL-76, and you'll want to put the car into mode V for the self diagnosis. It's pretty simple to follow the instructions, so if you can at least determine what the computer THINKS is wrong it's a start.
LEMHEAD16
'95 QofDOOM
'56 Chevy pick up
Thanks all.
I let a buddy drive the Q to Washington for a week. I'll test and report back when he gets back.
qsiguy
Car: 1994 Infiniti Q45 Turbo
Mine did that years ago and it stopped controlling the seat all together. I purchased a new door control pad off E-Bay and it fixed it. It's just now started doing it again in the last few months. Last time I opened up the defective one and couldn't find anything obvious. Probably time to replace the door control pad again for me.
qsiguy
Update, I just had to change my battery and when I got the new one in realized that the seat controls were no longer flashing and the seat controls work again. Maybe my old controller is also good, just needed a "reboot".
LEMHEAD16
'95 QofDOOM
'56 Chevy pick up
When I disconnect my battery it will stop flashing for a bit, but eventually it will start flashing again.
qsiguy
That's a bummer. Month and a half later, mine is still working ok.
Haitian_King
Car: 1992 Black Infiniti Q45 /w TCS
1995 Black Infiniti Q45
I have the same deal. All of my research leads me to believe that it's the BCM that's gone to hell since I can't let the car sit for more than one day before the battery dies. Just spent the afternoon trying to replace it and failed miserably.
goody90q45
goody90q45 wrote:Try this and let us know if it works.
4. Close the door
I left out the first step which is to disconnect the battery negative cable for about 10 minutes. See the thread below.
94-q45-plenum-rocker-covers-struts-and- ... t9818.html
LEMHEAD16
'95 QofDOOM
'56 Chevy pick up
After sitting for about 6 weeks with a dead battery, the light isn't flashing and my tilt/telescope works.
I'll have to keep an eye on it.
