If you hit the locked switched, it stays on at all time up to a certain mph (I guess over 30mph for instance, as it was blowing out/straining certain parts on the vehicle). At all other times, power is only transferred to the necessary slipping wheel, which is why it shows that its always on. You're not really getting power to all wheels at all times in most instances.BeachMom wrote:I thought the Lock and Unlock button would turn it off as if the car didn't have it. Thanks for clarifying that it is always on but just not "locked". Would love an explanation of what "locked" means.
I believe the manual is stating it correctly.RobGinPeabody wrote:My only grips is that Nissan corrects this in their owners manual, takes out that you should never drive with AWD lock engaged on flat, dry roads (if you have no choice to turn it off anyway), and maybe state in there that the light being on constantly is a normal thing.
Yes, but they also state in the manual not to drive with it in "Auto" mode on either if you are on a flat, dry surface; on other words, Auto is okay as long as it is wet/icey and/or slippery, which varies considerably given where you live. That's where they go wrong. Also, they need to state in the manual that the green light stays on all the time and that is it normal. It DOES NOT state this. So, the manual needs to be updated. Anyway, I got the answer I needed (thanks in very large part to YOU! ) and I hope others will read this if they have the same question.sprocket wrote:I believe the manual is stating it correctly.RobGinPeabody wrote:My only grips is that Nissan corrects this in their owners manual, takes out that you should never drive with AWD lock engaged on flat, dry roads (if you have no choice to turn it off anyway), and maybe state in there that the light being on constantly is a normal thing.
Driving with the AWD lock engaged as referred to in the manual is when you engage the LOCK using the switch in the driver lower which will illuminate the "amber" AWD LOCK indicator ... they are advising not to keep it in LOCK mode when not needed.
1019throw does an excellent job explaining this but, really, I can't see where you would use the lock button anyway except for in rare situations or where you either are or have the potential to be stuck. Glad it helped you out too though BeachMom.BeachMom wrote:I thought the Lock and Unlock button would turn it off as if the car didn't have it. Thanks for clarifying that it is always on but just not "locked". Would love an explanation of what "locked" means.
