Yeah I already sent them the photos and asked for a replacement. I feel like I had to be the one who got the short end of the stick here. Well let's see if the replacement gives me problems, if so I'm getting my money back plain and simple.Jake The Snake wrote:It's fine to just upgrade the front sway bar. Many cars come with only a front one. That's really unfortunate that they don't fit. Maybe the shop could make new end links for you by cutting yours and welding in a section. Godspeed is an ebay brand around the quality of megan, but any company can make hit and miss products. If you send them back and want something better, I always hear sikky makes good stuff.
Is your car lowered? That could possibly be part of the problem as well. Not too familiar with s13 sway bars but when I lifted by jeep they would no longer reach so I just removed the rear sway bar. Not a very important piece on a jeep, but obviously important for your 240.
Good luck man!
Thanks that actually helped. I guess I won't worry much about it.Hijacker wrote:The stiffness of the bar is partly dictated on how long those arms are that go back to the end link (this is how Whiteline can have adjustable bars as you change how long the fore/aft section runs). So in short, it's not gonna be an issue that the end link is bushed back a little. It might end up causing extra wear and tear on the end link. If it's something you worry about and can't sleep at night, upgrade to some aftermarket end links.
To give you an idea, I snagged these two pictures from MOTO IQ
-This is an ideal bar. Most bars make compromises in design for bits and pieces of the car to snake around. Those extra angles and shapes can be tough to model.
-This is the formula you would use to dictate the strength of the arm. As you can see the arm length plays a square effect on determining the strength of the arm. The diameter plays the biggest part however. All measurements are in inches for this formula.
