Yub, cheappo Sportmax wheels and Godspeed suspension saved my a**z32pilot62 wrote: I do believe B4CH did prove something with his post though...
what kind of arms do you have on your z?ArticDragon192 wrote:In the long run, you'll end up buying arms again because those heim joints will not last.
Over 3 years of street and track abuse on my arms and no problems whatsoever. Quality parts work right now and years down the road.
I would consider it if I could get them in the same spring rates front and rear, I has a 2+2 so I think it would be more balanced to have it have the same spring rates front and rear. Thats the way arctic has his set up and I think it is probably the way to go with the more 50/50 distribution with the 2+2's.Initial R wrote:^^^ So after all that. Anyone want to give this a try ? I know I would if they offered it 3 months ago when i was upgrading my suspension.
http://cgi.ebay.com/ebaymotors/90-96-30 ... ccessories
Why not just replace the heim joints rather than replace the whole arm? Im sure you could get a better quality heim joint to replace the ones that come on the arms and as long as the quality of the arm itself is holding up whats the point in buying a whole new one?ArticDragon192 wrote:In the long run, you'll end up buying arms again because those heim joints will not last.
AmenArticDragon192 wrote:In the long run, you'll end up buying arms again because those heim joints will not last.
Here, I'll save you some dollars. All you need to get your alignment back into spec with those springs is the 300° camber kit.putang29 wrote:enough to correct the negative camber you get from lowering a 90 n/a Z with eibach sport/kyb agx combo
I have Powertrix FUCAs, stock RUCAs, Peak Performance Tension Rods, SPL outer tie rod ends, and Peak Performance rear toe rods. I will be upgrading to Powertrix all around though soon enough.nuttin but Z32 wrote: what kind of arms do you have on your z?
im thinking about getting some camber in my z
You can, but why? When you can just buy right the first time around. Plus, the welds on cheaper components are pretty crappy looking. Little thing here and there make the cheaper products really inferior. Plus, I also believe that someone can get too strong an arm. In a crash, I want the tension rod to be the weak point, not the LCA. If the tension rod can absorb most of the impact and break before transferring that force to the LCA, I can save myself a good amount of cash.z32pilot62 wrote: Why not just replace the heim joints rather than replace the whole arm? Im sure you could get a better quality heim joint to replace the ones that come on the arms and as long as the quality of the arm itself is holding up whats the point in buying a whole new one?
I'm glad there are some sensible people out there.BigTDogg (MA) wrote:
Amen
LIBRILZ wrote:Arctic, why did you keep stock rucs? You can't adjust camber with it can you..? Also what did you do for more steering angle. That is always nice.
Wrong, the stock RUCAs have a slight bit of adjustment through them with an eccentric bolt that slides the arm either in or out to adjust camber. However it is a very small adjustment, which I have maxed out.es.biggs wrote:Lower control arms on the rear have an eccentric bolt for camber don't they?
I noticed that alot about my 2+0 when I had it compared to my 2+2. The 2+0 was real "a** happy" for lack of a better term and my 2+2 is real stable slideways.LIBRILZ wrote:I plan in the near future to slide the 2+0, wish me goodluck as it seems all it wants to do is spin out and do 180s lol..
