BCC93QT »
https://forums.nicoclub.com/bcc93qt-u89202.html
Sun Apr 12, 2015 12:15 am
I don't know if I trust rock auto with their so called OEM "iridium" plugs I saw last time. I compared and I think it was like an $18 difference for 8 plugs from the dealer. As far as the PCV 12 years ago when I accrued my Q the PCV valve was supposedly in need of replacement as per the nissan dealer. One of the first parts I attacked myself on my Q along with many others. It may be cheap to replace but a $5 can of cleaner whatever I cleaned it with (honestly can't remember. Carb cleaner? or?) is more satisfying than replacing the $20+ part? I haven't touched it since. I could be wrong but within my experience of maintaining a broad range of engines they just get clogged and stuck. I don't think I have ever actually replaced one. Even though it is a dirt cheap part it can still kill your engine as if its malfunctioning it will mess with your oil pressures. Clean it ASAP. If for some reason you can't get peace of mind cleaning it, spend the $20 something bucks replacing it. But I don't think a PCV valve EVER needs to be replaced.
*Can't sleep. For some reason I needed a Q45 fix at 3:30am eastern. hope it helps. Maybe I can't sleep because the Bruins raped my faith this year. Paul, where the frick are ya, I know you're disappointed too.
