bredtime »
https://forums.nicoclub.com/bredtime-u142783.html
Fri Oct 16, 2009 4:46 pm
"Gasoline retailers and refiners like high-test because it's more profitable than regular-grade gas is. The retailer paid about 8 cents more for the premium you pay 20 cents more for — though that margin can swing wildly. Refiners make a few cents a gallon more on premium than on regular when they sell to wholesale distributors.
As long as it's clean
Profit is meaningless to the modern engine, which, regardless of what's specified in the owner's manual, hardly cares what you use — as long as it's clean.
Today's engines use highly evolved versions of a device called a knock sensor to adjust settings automatically for low-octane gas. And more engine control computers have adequate memory to allow separate sets of instructions for various octanes. The engine control computers keep pushing to maximize performance on whatever grade of fuel is used.
Extreme pressure inside the cylinders causes knock, which is the sound of the pistons literally rattling inside the cylinders. Too much too long can damage the engine. A little now and then won't.
The only modern engines that should really need premium are those with superchargers, which force-feed fuel into the cylinders. "You're driving along and just tramp the gas and the knock sensor cannot sense the knock fast enough in some cases," because the supercharger boosts pressure so fast, says Bob Furey, chemist and fuels specialist at General Motors.
Burning regular when the owner's manual specifies premium won't void the warranty, nor damage the engine, even the most finicky automakers say. "You're giving up perhaps just a little bit of performance that a customer wouldn't really even notice, it's so slight," says Furey.
Automakers say they don't test premium engines on regular to check the difference, but some auto engineers estimate that power declines roughly 5%.
"We can't guarantee the vehicle will perform as specified if other than premium fuel is used," says Mercedes-Benz spokeswoman Michelle Murad. All U.S. Mercedes engines specify premium.
All Porsche engines are designed for premium, too, but it's not available everywhere. "Our cars must be able to drive all over the world, and so we are able to run on regular," says Jakob Neusser, director of powertrain development at Porsche's research and development center in Weissach, Germany. "You don't have to feel that a mechanical problem or anything else will happen" using regular gas, even in the highest-performance, regular-production Porsches.
Premium, in fact, sometimes is worse fuel than regular. It resists knock because it's harder to ignite than lower-octane fuels. As a result, some engines won't start as quickly or run as smoothly on premium, notes Gibbs, the SAE fuel expert.
High-test does have a potential fuel economy benefit. It is slightly denser than lower-octane gas, meaning there's a little more energy in a gallon. But the small difference is hard to measure in real-world use, and that same density can contribute to undesirable buildup of waste products inside the engine.
No data show that engines designed strictly for regular run better or longer on premium.
The Federal Trade Commission, in a consumer notice, emphasizes: "(I)n most cases, using a higher-octane gasoline than your owner's manual recommends offers absolutely no benefit. It won't make your car perform better, go faster, get better mileage or run cleaner."
There is "no way of taking advantage of premium in a regular-grade car," says Furey.
"There is no gain. You're wasting money," insists Jim Blenkarn, in charge of powertrains at Nissan in the USA.
"No customer should ever be deluded into thinking there's any value in buying a higher grade of octane than we specify," says Toyota's Paul Williamsen, technical expert and trainer.
But premium retains a mystique.
Even Mayne, the sensible Subaru owner who has switched to regular, says she'll buy premium when her neighborhood station has a special price. "It's my perception that I might get better gas mileage or that it might be better for my engine," she says.
"I would stop driving rather than use a lower grade of gasoline," says Andrew Martschenko of Boston, who drives a 2003 Nissan Maxima. Nissan says premium is "recommended" for that engine — automaker code for regular is OK, but you'll only get the advertised power on premium."
