Do not get intake or reflash .. these will not help your dilemma. Only to make it worse.
There really isn't any modifications for the car. But perhaps the driver.
A good read:
http://www.nicoclub.com/tech/gas-mileage.shtml
Of the big things to understand is how you drive.
At a green light ease on the accelerator slowly, the faster your speed is the more unsteady the fuel flow into your engine is...in turn more unsteady more fuel consumption. Your goal is steady flow for fuel economy.
Second is coasting. Plan ahead, instead of speeding up to a stop light, let the car coast to the stop light. You will need to begin coasting sooner than conventional braking. This here will make you a better driver too. Each time you have to use your brakes is energy lost, and energy you have to make up with fuel. If you coast correctly, you may be lucky enough to get to the light right when it turns green. This means that you will be at motion when it turns which then means less fuel it takes to bring you back up to speed. (Which brings back to the first topic slow acceleration)
Fuel is what puts your car in motion, your goal is to keep it in motion. And that's fuel savings.
If I follow these and I can get 38 mpg out of my daily, all because I choose to drive smart.
And finally during short trips. When you first start your car up it is running on a closed loop to warm your engine up. It adds more fuel to increase the rev at idle. You can spend a few mins letting the car warm up, this also prevents start up wear and tear.
Check air filter and spark plugs.
And remember I am not saying don't enjoy your car. It just costs if you do.
As for pics.. you need to find a image host like photobucket or flickr. Once you upload your image there, they will give you a URL to that image.
Then on here put the URL between [*img]URL[*/img]..note I added * so you can see the code for adding the image tags, you will want to type them without the *. Keep in mind that image host may already provide the [*img][*/img] tag with the url.. then it's just simple copy and paste here.
Enjoy.
Modified by Rare_f8 at 10:13 PM 1/22/2009
