3Q Jay »
https://forums.nicoclub.com/3q-jay-u16163.html
Sat Aug 11, 2007 7:41 pm
Tom, what you and i did the first time is exactly what Jared (silver 2k2) is suggesting. so, the short answer is that is a pure loopback hose is used, the reservoir would be out of the circuit, and whatever fluid is in there (i would actually expect it to be empty) won't get to the pump. why i was suggesting to keep the suction hose connected between reservoir and pump, and send the pump output (what used to go to the main front accumulator) back to the reservoir for circulation.
squeak? check the belt tension, especially if it has not been adjusted since the pump was installed 6k ago. maybe? that is all you need. i replaced the water pump/active belt and tensioner, and then had to go back in a week later and re-tension (had squeaking, especially on shift at hard throttle).
